August 23, 2024 at 10:59 pm
Yuanyuan Xiao
Ansys Employee如题,谢谢。
August 23, 2024 at 11:01 pm
Yuanyuan Xiao
Ansys EmployeeFluent 粒子计算结束后,如果是做的稳态粒子,可以在Particle Tracks窗口点击Pulse来看粒子的运动轨迹。
若想保存该动画,即生成视频文件,则操作方法如下:
Fluent计算结束后导出粒子的历史数据.xml文件。File->Export->Particle history data
在CFD-Post里导入上述文件;
导入历史数据文件后,在CFD-POST结构树下出现一个 Fluent PT for ****,双击Fluent PT for*****,在Symbol面板勾选“Show Sypmbols”并点击apply。
- 您必须登录才能回复此主题。
- Application of EDC occurs flame extinguishing
- Must EDC model need an initial flow field?
- Difficulty in Complex Source Term Linearization
- Please help me check if there are any issues with the UDF.
- Negative droplet growth rate in Fluent wet steam model
- Energy Source Term formulation for multi-component condensation
- Compile the UDF code and apply it to the DPM.
- Please help me analyze the multiphase flow model for the phase change of liquid
1885
1403
1298
