TAGGED: coupled-simulation, orientation-of-fibers, rocky-dem
January 13, 2025 at 11:11 pm
January 14, 2025 at 2:29 pmLucas Bertollo BaggioAnsys Employee
It is possible to export any particle data from the Properties tab for each particle by using the PrePost Scripting. Check on its manual here.
For this case, it will be written as something like
project = app.GetProject()
study = project.GetStudy()
particles = study.GetParticles()
orientation_vector = particles.GetGridFunction('Orientation : Vector : X').GetArray(time_step=i)it will save the data for all particles as an array that you can export using python.Â
best regards,
Lucas
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
624
599
591
366
