July 8, 2026 at 4:51 pm
emsantos
SubscriberReviewing the System Coupling User's Guide (Release 2026 R1), the list of supported coupling participants includes Mechanical/Mechanical APDL, Fluent, CFX, Forte, Electronics Desktop/Maxwell, FMU, Thermal Desktop, Rocky, and Files - but LS-DYNA does not appear in this list.Therefore, if possible, I'd like to clarify the current status of coupling between Ansys Rocky (DEM) and LS-DYNA.ÂSo far, I've found clear documentation for:Â- Rocky ↔ Ansys Mechanical (1-way and 2-way, via System Coupling)- Rocky ↔ Ansys Fluent (CFD-DEM)- LS-DYNA participating in System Coupling with Fluent and MAPDL- A sequential/homogenization workflow linking Rocky → Multiscale.Sim → LS-DYNA (Cybernet's Multiscale.Sim add-in), which is one-way and does not preserve time-resolved feedback between the two solversÂMy specific questions:Â- Is direct two-way co-simulation between Rocky and LS-DYNA officially supported today (2026 R1/R2)? If so, is it via System Coupling, or another mechanism?
- If supported, is LS-DYNA's participant status in System Coupling still a beta/experimental feature for this type of coupling, or has it reached production maturity?
- Are there known limitations regarding the time-step mismatch between Rocky's DEM solver and LS-DYNA's explicit time integration (microsecond-scale)? Is subcycling or another mechanism used to reconcile this?
- Is there a reference case, tutorial, or technical manual (beyond the general System Coupling User's Guide) that documents this specific Rocky↔LS-DYNA workflow?
- What licenses/executables are required (e.g., a special LS-DYNA build with SyC DLLs, as required for LS-DYNA↔Fluent coupling)?
Any pointers to official documentation, technical support cases, or example projects would be greatly appreciated.Thanks in advance! -
July 10, 2026 at 12:30 pm
Nanda
Ansys EmployeeHello User,
Please give us sometime to check on this.
Nanda.
Have a look at our public help documentation website:Â Ansys Help
For more exciting courses and certifications, hit this link:Â Ansys Innovation Courses | ANSYS Innovation Space
July 13, 2026 at 9:36 am
Nanda
So, two-way coupling is not possible as of now. I don't have any information whether this development is being carried out at the moment.
I found one internal resource which talked about one-way coupling from Rocky to LS-DYNA. If you're looking for more detailed support on this, please raise a support case if you're eligible to do so.
Best,
Nanda
