May 25, 2023 at 9:38 amranko simicSubscriber
in workbench i've connect solution from Fuent node with results in Results node. When i start edit results I've got error with message 'The application has encountered an unexpected problem and will now terminate ' ... have you got any idea what is problem
thanks
May 25, 2023 at 2:30 pmFedericoAnsys Employee
Is your Solution complete with the green check mark? When you right click and Edit... what is the application that Workbench tries to run?
May 26, 2023 at 8:05 amranko simicSubscriber
yes
when i right click on results end left click on on Edit in popup window, workbench try to start cfd-post
May 29, 2023 at 1:09 pmFedericoAnsys Employee
Hello Ranko,Â
what version of Workbench are you using? Is this a Student license? What is the size of the mesh and the format of the output files for CFD-Post?
You could also try using Ensight for your post-processing.
- The topic ‘results’ is closed to new replies.
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- error udf
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- UDF, Fluent: Access count of iterations for “Steady Statistics”
1416
599
591
565
366
