December 30, 2024 at 2:34 pm
ashishkumar.gupta
Subscriber -
January 3, 2025 at 1:21 pm
January 3, 2025 at 2:08 pm
Ashish Khemka
Forum ModeratorHello,
What is the error message you see when using the outer surface of the ball for remote point definition? I am assuming that you are defining contacts as well using the same surface and it might be conflicting with the remote point definition. For the first approach - it seems you are using half-symmetry. What is the reason that you doubt that results might be incorrect?
Ashish Khemka
January 3, 2025 at 2:18 pm
ashishkumar.gupta
SubscriberYes, I am using half symmetry. since I have applied Remote Displacement on the Plane surface of Half ball, I am not able to see any rotation.
I guess the right way would be apply Remote Displacement on the curved surface of the ball.
Should I switch to Full Ball Model instead of this Half Ball model?
or the Current Half Ball Model with Remote displacement on the plane surface of Ball is correct?
January 3, 2025 at 2:26 pm
Ashish Khemka
Forum ModeratorHi,
Thanks for providing the update. Instead of remote displacement - you may try creating a body-to-ground revolute joint for balls and define a frictional contact between ball and groove. To move the balls apply a joint load for the revolute joint.
Ashish Khemka
January 3, 2025 at 2:32 pm
ashishkumar.gupta
SubscriberÂ
Hi Ashish, That doesnt support my theory of Contact Mechanics. I am doing 2 way FSI.
So only option is Remote Displacement. But The only doubt I have on which surface should the remote displacement be applied? Also, is Half Ball Model fine?Â
Please update on this ....thank you!!
January 3, 2025 at 2:39 pm
Ashish Khemka
Forum ModeratorYes, using the half-ball model with remote displacement (free rotation about z and displacement in z=0) should be fine.
Ashish Khemka
January 3, 2025 at 2:41 pm
ashishkumar.gupta
SubscriberLike Remote Disp. applied on plane surface? then why do I not see any rotaional movement of ball?
January 3, 2025 at 3:02 pm
Ashish Khemka
Forum ModeratorWhat are the loads applied? I do not see any rotational load being applied to the ball.
Ashish Khemka
January 3, 2025 at 3:36 pm
ashishkumar.gupta
SubscriberÂ
The rotational Velocity are applied to Inner Race (+ 1000 RPM) and Outer Race (-658 RPM) …which means Ball can rotate around its own axis in the same position (corr. constraints are applied in form of Remote Disp.)
January 6, 2025 at 8:14 am
ashishkumar.gupta
SubscriberHi, could u please confirm?
January 6, 2025 at 9:53 am
Ashish Khemka
Forum ModeratorHi,
Rotational Velocity accounts for the structural effects of a part spinning at a constant rate. Instead of that you can define revolute joints (body to ground) for inner and outer races.
Ashish Khemka
January 6, 2025 at 10:11 am
ashishkumar.gupta
SubscriberÂ
so u wanna say Rotational velocity would not give me Rotational Effects or I would not able be able to Rotation?Â
Ball Bearing has no Joint effect …I do not think  revolute joints would fit here…..It would not create the contact stresses I want ….
Maybe could you please confirm with ur colleagues?Â
January 6, 2025 at 10:59 am
ashishkumar.gupta
SubscriberÂ
Also, I have only modeled 40° out of 360° ….which is 1 ball with part of IR and OR…. All bodies are free to deform in XY plane....but No deformation & only rotation around Z axis
My ball bearing should Rotate in Ansys Mechanical (Transient) and this will cause Fluid to move in Ansys Fluent (Transient – Sliding Mesh Tech with Dynamic Mesh) —–> 2 way FSI. [Mech – Fluent -System Coupling ]
So my B.C. should be:
Inner Race:Â Revolute Joint (Body to Ground ) +1000 RPM
Outer Race:Â Revolute Joint (Body to Ground ) -658 RPM
Ball:Â Remote Disp. (Rz= Free) around own axis.
Between Ball and Races, there is fluid (in Ansys Fleunt) which will transfer Pressure forces to Mechanical body …..so contact is kept ‘Frictionless’ as there will never be Metal-Metal conatct
Right?
January 6, 2025 at 11:35 am
Ashish Khemka
Forum Moderator-
January 6, 2025 at 3:05 pm
ashishkumar.gupta
SubscriberThank you Ashish for the informative description with pictures.
In my Case, Ball and Race are not touching each other. which means Fluid is present and it is modled in Fluent ...so 2 way FSI.
do you think Revolute joint will work?
January 6, 2025 at 3:09 pm
Ashish Khemka
Forum ModeratorHi Ashish. let me ask team to comment more on this.
Thanks,
Ashish Khemka
January 7, 2025 at 8:12 am
ashishkumar.gupta
SubscriberHi Ashish, any update from the team??
January 6, 2025 at 4:08 pm
January 13, 2025 at 6:40 am
Ashish Khemka
Forum ModeratorHi Ashish,
I have defined revolute joint for races but the ball is free to move between the races due to frictional contact. Movement of ball seems realistic but for races you will need to check if they only rotate or have any other loads as well.
Ashish Khemka
5939
1307
