Regarding simulation of bonding two polymer plates
    • amahar3
      Hi. I wanted to do the simulation of bonding two small polymer plates by heating the plates near the glass transition temperature and applying external pressure from all sides. The simulation also need to show air bubbles entrapped between the bonding interfaces because of insufficient applied pressure. Is it possible to do this simulation in ansys? Any suggestions would be highly appreciated. Thanks.
    • Supreetha J
      Hello Anish,
      Kindly refer to this Forum discussion Simulation of bonding two polymer plates (ansys.com)
      I hope this helps.
      Thank you.
  • The topic ‘Regarding simulation of bonding two polymer plates’ is closed to new replies.
