February 23, 2023 at 10:44 am
Manu Krishna
SubscriberIs there any feature in APDl such that the real constant value of a spring element could be saved into dynamic variable. i was planning to do a parametric optmisation for a spring system, but i could not add the real constant value like stiffness and dampings as a input parameter. if anyone has any idea pls support.
February 23, 2023 at 12:33 pm
ErKo
Ansys EmployeeÂ
Hi
Yes should be able to just call/name it kk (=55) say and use/change that. See example:
/prep7 Â
*SET,kk,55Â Â ! or kk=55
et,1,14Â
!* Â
KEYOPT,1,1,0
KEYOPT,1,2,0
KEYOPT,1,3,0
!* Â
R,1,kk, , , , , , Â Â
RMORE, ,Â
All the best
Erik
- The topic ‘Real constant for element’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
1494
1386
1209
