April 23, 2021 at 11:48 am
ANSQ3DSF
SubscriberDuring my incorporation into ANSYS Q3D Extractor some questions regarding the solution process arose. In the following, those questions are further explained.nAccording to the Figure on Q3D Extractor Help 21 ? 3, Q3D Extractor divides the solution into a DC-Region, a Transition Region and an AC-Region. In the DC Region the current is evenly distributed along the conductors crosssection. The documentation says that this assumption is valid for frequencies, where the skin depth is greater or equal than the conductors thickness.nIn the AC Region the magnetic field is completely displaced from the conductor (no inner inductance any more?!, solely magnetic flux through surface has a contribution) and current flows only on a thin layer (resistance proportional to the square root of the frequency). It is said, that this assumption should be fulfilled when the skin depth is less or equal to one thirds of the conductors thickness.nThe solution for frequencies in the Transition Region is calculated by the equivalent circuit shown on Q3D Extractor Help 21 ? 4. Thereby, a simple interpolation is utilized.nDoes that mean, that the difference between AC Inductance and DC Inductance equals the inner inductance?nFor instance, we want to achieve a solution of the inductance and resistance in a specific frequency range. Lets say our conductor is 100?m thick. According to the procedure described above, we should be fine to calculate the DC-Inductance and the AC-Inductance at a frequency where the skin depth is 33?m. This is enough information to approximatly determine the frequency-dependent inductance.nVice versa does that mean we cannot obtain a more exact solution in the transition region when using Q3D Extractor? And, if so, what influence does the choice of the solution frequency have?.Capacitance and Conductance is determined by an electrostatic simulation. nThe reason for the frequency dependence of the capacitance is the frequency dependence of the dielectric materials?n -
August 12, 2021 at 4:41 pm
Charlotte Blair
Ansys EmployeeHi,
Inline with your questions:
Yes - The difference between the AC inductance and the DC inductance is typically the inner inductance of a structure.
Correct - The Q3D solver does not solve inside the metal for the transition region. If you do want this accuracy please use our HFSS tool and check solve inside for metal
The solution frequency selection helps us insure that we are solving at the operating frequency of operation of the model. If you are interested in transition region just make sure solution frequency is above it.
Yes - Capacitance and Conductance is determined by an electrostatic simulation which includes frequency dependency of material.
Hope this helps!
- The topic ‘Questions regarding the field simulation methods of ANSYS Q3D Extractor’ is closed to new replies.
1306
