November 4, 2019 at 9:35 pm
templor
SubscriberI'm working on extraction of parasitic parameters of power module by Q3D.
For default, AC resistance&inductance is extracted at 1GHz. The results from this setting looks good, and AC resistance is much greater than DC resistance due to skin effect and proximity effect.
However, the results are wired when I change the solution frequency to 60Hz or 20kHz, the DC resistance is 10 times larger than AC.
Does anybody have the same issue, or give me some suggestion about it?
Thanks.
Bo
December 28, 2020 at 2:01 am
Mayank
SubscriberHi..templornI am also working on Q3D and facing the same issue .nDid you found some reason for that ?n -
January 14, 2021 at 11:59 am
rtk
Ansys Employee, nI would suggest going through the Q3D Extractor help document covering AC vs. DC Analysis. This has covered the interpretation of the AC and DC regions by Q3D extractor.nSo for your case at 60 Hz or 20 kHz, the skin depth might be greater than the actual conductor thickness and thus the AC resistance at this point cant be reliable. You should go for DC resistance. nYou might need to check what is the threshold frequency at which you can rely on both AC and DC resistance for your model according to the expressions in the help document.nHope this addressed your concern.nnRegards,n -
January 23, 2021 at 4:01 am
Mayank
SubscriberThanks n
- The topic ‘Q3D issuse: why DC resistance is greater than AC resistance at 60Hz and 20kHz?’ is closed to new replies.
1311
