October 27, 2024 at 7:10 pm
October 28, 2024 at 12:06 pm
Deepak
Ansys EmployeeHi,
Please check whether the Design region bodies are selected the same in both the Optimization Region and Design Constraint.
Deepak K.
How to access the ANSYS Online Help -
October 29, 2024 at 7:23 pm
258344
SubscriberMy main problem was when I connected optimization to static structural. At that moment, a question mark appeared here, and nothing could be done about it. I have selected regions in all different ways.
February 17, 2026 at 10:49 am
abdullokh.orifjonov
SubscriberIn my case, it seems that Optimization Region shows “?” sign due to a presence of nonlinear contacts. The Ansys help lists nonlinear contacts as a known limitation of a Density Based topology optimisation method.
Solution: use only linear contacts (Bonded or No Separation) if you can. If you insist on keeeping nonlinear contacts, enable Beta Options in Workbench Options > Appearance.
5869
1306
