February 3, 2021 at 5:16 pm
toni1398
SubscriberWhen I try to add the licence info this is what appears. What should I do?
February 3, 2021 at 7:45 pmANSYS_MMadore
Forum ModeratorThe LICSERVER.INFO is not a license file. That file should be provided to your ANSYS Account Team or used at the Ansys Licensing Portal to create your license file based on the information it contains.nFebruary 3, 2021 at 7:59 pmtoni1398
Subscriber@toni1398 The LICSERVER.INFO is not a license file. That file should be provided to your ANSYS Account Team or used at the Ansys Licensing Portal to create your license file based on the information it contains./forum/discussion/comment/105512#Comment_105512
how can I create the license file? I am the host managernI did provide it to the account teamnFebruary 3, 2021 at 8:02 pmANSYS_MMadore
Forum ModeratorCan you share your account number so I can look into this? Your account manager should work with you and assist with using the Ansys Licensing Portal if that is how they would like you to obtain your license.nFebruary 3, 2021 at 8:08 pmtoni1398
Subscriber1136158nFebruary 3, 2021 at 8:12 pmANSYS_MMadore
Forum ModeratorThe ASC on the account should have received an email that the entitlements are available and ready to be activated. To activate them, the ASC will need to go to the Licensing Portal (licensing.ansys.com) and activate following this tutorial.nhttps://www.youtube.com/watch?v=7idHWwDVHrc&list=PL0lZXwHtV6OmAST1t6MHMyAM7f1wBXCLr&indexnnThank you,nMattnFebruary 3, 2021 at 8:31 pmFebruary 3, 2021 at 8:37 pmANSYS_MMadore
Forum Moderator1) Please update the version of the ANSYS License Manager, available from https://download.ansys.com/Current+Release.n2) In your C:\Program Files\Ansys Inc\Shared Files\Licensing\ansyslmd.ini file, please reference DESKTOP-P5J4K17 rather than a244a197. You can open the file with a text editor and then save it to your desktop. Modify with the correct hostname, and save it. Then copy/paste it back to C:\Program Files\Ansys Inc\Shared Files\Licensing\ replacing the existing copy.nnThanks,nMattnFebruary 3, 2021 at 8:41 pmFebruary 3, 2021 at 8:44 pmANSYS_MMadore
Forum ModeratorArray No, C:\Program Files\Ansys Inc\Shared Files\Licensing\ansyslmd.ini. It probably looks like this:n SERVER=1055@a244a197n ANSYSLI_SERVERS=2325@a244a197nmodify to look like this:n SERVER=1055@DESKTOP-P5J4K17n ANSYSLI_SERVERS=2325@DESKTOP-P5J4K17nnThere may be permissions preventing you from saving directly to C:\Program Files\Ansys Inc\Shared Files\Licensing which is why I suggest saving to the desktop and then doing a copy/paste back to C:\Program Files\Ansys Inc\Shared Files\Licensing.nThank you,nMattnFebruary 3, 2021 at 9:11 pmtoni1398
Subscriberok thanks, it is workingnanother question:nwhat do i have to do if i want to change the ansys version?nfor example, i need ansys 19.0 but i installed 2019 r1nFebruary 3, 2021 at 9:25 pmANSYS_MMadore
Forum ModeratorYou can download from https://download.ansys.com/Current%20Release?releaseno=19_0&operatingsystem=Windows%20x64nnThanksnMattnFebruary 4, 2021 at 4:28 pmvganore
Ansys EmployeeToni, Estevez is an ASC for this account. So please contact him for 19.0. He has access to the Ansys customer portal for downloading the product. nViewing 12 reply threads- The topic ‘Problem with licence manager’ is closed to new replies.
5779
