March 19, 2022 at 11:26 pmAMR96Subscriber
I am doing a project on CFD simulation of a PEM fuel cell. The main goal of the project is to simulate and verify the results of the fuel cell with what is already present in literature.
The model that I am currently simulating runs in the transient mode and I get fairly good residual curves after simulating the model for 10 time steps with a step size of 1e-09 and 30 iterations per time step. The problem that I am having is that after the simulation is done, the contours of the hydrogen mass fraction on the anode side show a constant value. In reality the hydrogen mass fraction has to decrease as we approach the anode outlet. Additionally, the min_h2 and mean_h2 are the exact same value as the simulation progresses which doesn't seem correct.
I have no idea where the problem is. I have double-checked my inputs with what is in the literature and there is very little difference however I still don't know why the hydrogen mass fraction doesn't change.
I would like to know if anyone has encountered such problem or know what is causing this issue?
Any is help is very much appreciated.
March 22, 2022 at 12:30 pmKarthik RemellaAdministratorHello:
Do you see the decrease at such low time scales (1e-9 to 1e-8 s)? Or do you need to run the simulation a little longer to see some decrease? The time scale of the problem might be something to think about here.
Karthik
Viewing 1 reply thread- The topic ‘Problem with Hydrogen mass fraction in PEM Fuel Cell model.’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Fluent fails with Intel MPI protocol on 2 nodes
- Cyclone (Stairmand) simulation using RSM
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
Top Contributors-
1722
624
599
591
366
