February 3, 2018 at 2:48 pm
February 8, 2018 at 1:40 pm
February 9, 2018 at 12:49 pm
diegosdv
SubscriberAre you also using a windows 7 version?
February 10, 2018 at 6:05 am
sefacancakmak
SubscriberYes i am using windows 7 proffesional.
February 12, 2018 at 7:48 pm
Edilson Rosa
SubscriberHi everyone!
I also had this problem when I installed version 18.2, I easily fixed that by the following settings:
Click on: FILE > SpaceClaim Options > In Advanced > Graphics > Verify what kind of GPU are you using (by default after installation is selected DIRECT3D11). It worked when I chose DIRECT3D9.
Hope this helps.
Edilson Rosa -
February 13, 2018 at 2:57 pm
diegosdv
SubscriberThank you Edilson!! It worked here, problem solved!!Â
September 4, 2018 at 7:34 pm
lucasalves
SubscriberThank you Edilson, it had happened with the ANSYS 19.1.Â
July 11, 2019 at 6:11 am
vidhan28
SubscriberI'm not having the Direct3D9 option...what should I do?
July 11, 2019 at 4:18 pm
tsiriaks
Ansys Employeeit does not have to be Direct3D9 , you can try other rendering mechanism.
October 30, 2020 at 3:36 pm
thansiyapa_gmail_com
SubscriberIt is showing...nDirect3D11nDisablednWARPnOpenGL...nSo what should i choose.... Can u suggestn
Viewing 9 reply threads
- The topic ‘Problem opening SpaceClaim using ANSYS 18.2’ is closed to new replies.
1890
1419
1304
