July 13, 2023 at 7:15 am
xuanlunhuang20
SubscriberI’m simulating a meta-structure and I add a field monitor to view the E field. But I find that the x component in E and the Ex data are different.
I right click the E and show the x component, it looks like this:
I right click the Ex data and it looks like this:
It can be seen that the scales of these two results are different. So, when I plot Ex with the x and z, it is not correct. Even though I save the whole E result and plot the first column, i.e., Ex, it appears like the second case.
But the correct one I think should be the first case. Why does this happen and how to solve this? Thanks.
July 17, 2023 at 4:18 pm
Niki Papachristou
Forum ModeratorHi Xuanlun Huang,
Thank you for you post at our forum. I see that in one case you are plotting the simulated E data while in the other case you are getting the index numbers, hence his plot in this case looks a little bit stretched. You should note that neither plots (as is) show the true dimensions of the structure. For example in the second plot the x span and y span of the plot are similar in length, but in reality it's ~0.6um vs 10um... and if you change the size of the window the results appearance change as well. However, I agree that first plot is preferable, since it corresponds to length, while the second format is corresponding to the number of points and loses this information.
Kind Regards,
Niki
- The topic ‘Problem in plotting the E field’ is closed to new replies.
