TAGGED: /post1, ansys-mapdl, apdl, error-in-results, extract-results, mapdl, nodal-results, postprocessing
November 20, 2024 at 8:18 pmfilippobarbagelata07Subscriber
Greetings to everyone,
I'm recently sruggling with the MAPDL post processing commands, I included a command block in the result tab of the mechanical simulation tree executing commands after the /post1 apdl command.
I'd like to modify the resulting stress value of nodes that exeed a certain value with the *DNSOL command but I can not extract the stress values from any node using the *GET command.
How can I get the equivalent stress values at the nodes? I need it in order to select all the nodes with a greater stress value then a prescribed value and modify it
Thanks to anyone who will reply
November 21, 2024 at 9:01 amDeepakAnsys Employee
Hi,Â
*GET - used to define scalar parameter
*VGET - Retrieves values and stores them into an array parameter, the below code helps in extracting the equivalent stress values of all nodes and stores them in the VOM_STRESS parameter.
*VGET, VOM_STRESS, NODE,0, S, EQV.
Then you may use the *IF and *DO loop to extract the data from the VOM_STRESS array for the nodes whose stress value exceeds the prescribed value.
Reference links: *VGET; *IF; *DO
Thanks,
Deepak
November 25, 2024 at 9:43 amfilippobarbagelata07Subscriber
ok, thank you for your help, the code now works fine replacing the results i want to edit with the *VPUT command, now I have another problem. I need to update the equivalent stress plot to show the edited results to perform a fatigue analysis. Is there a command that can do such thing?
November 25, 2024 at 1:15 pmDeepakAnsys Employee
Please look at these KM, maybe these will be helpful to you,
How to plot user define result in APDL for (2^(P1) P1 =Principal Stress | Ansys Knowledge
Thanks,
Deepak
- Workbench license error
- Unexpected error on Workbench: Root element not found.
- Unexpected issues with SCCM deployment of Ansys Fluids and Structures 2024 R1
- AQWA: Hydrodynamic response error
- Questions and recommendations: Septum Horn Antenna
- access to path files denied error
- Tutorial or Help for 2 way FSI
- Unable to connect to the license
- Moment Reaction probe with Large deformation
- Ansys with Vmware and CPU configuration : I’m lost, good practice?
1722
624
599
591
366
