July 14, 2020 at 4:43 pm
joshstew
SubscriberHi,
Using Maxwell3D, I performed a parameter sweep using on two objects where I am looking at the E-field intensity. I would like to plot the maximum E-field intensity for each of my sweep parameters on a single plot.
I have looked at the help section but I don't see an option to plot the E-field magnitude. I right clicked Results, selected Create Fields Report>Rectangular Plot but don't know where to go from there. I've attached a screenshot of the options I see.
Any help with this is appreciated.
July 17, 2020 at 2:08 am
icellb
SubscriberHi,Â
You can create a named expression by calculating the max E-field in the object in field calculator. Then when you create Fields Report>Rectangular Plot, the named expression will appear for you to choose as the y axis.Â
July 17, 2020 at 12:18 pm
NKC
Forum ModeratorHi Joshstew,
Yes, you can write a user-defined expression using the field calculator for deriving the required parameter.
Right-click on the field overlays > field calculator
create your expression and add it to Named expressions.
Now, right-click on the Results and plot that named expression from the create fields report option.
Regards
Navya
- The topic ‘Plotting Maximum E-field values from parameter sweep’ is closed to new replies.
5884
1306
