December 6, 2023 at 4:44 pm
Xia Du
SubscriberHello, I am using Matlab to call Ansys Q3D to do some optimization design of a Rogowski coil. And during one simulation, Q3D showd the error "Parasolid Error: Failed in function PK_BODY_boolean_2 with error PK_ERRO", so that the windings can not be created. However, if I use the same parameter that generated in Q3D to draw the windinds manually, it works.
Can anyone explain me what the parasolid error means and why this is happening? I would really appreciate it! The ansys version I am using is 20233 R1.Â
December 10, 2023 at 1:45 pm
Praneeth Munaga
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum. Your patience is much appreciated.
Kindly share the full log of the error to help us serve you better.
It is stated that you were able to create the geometry manually in Q3D. If it is so, then there would be some issue with the Matlab script. Please check once.
Best regards,
Praneeth.
- The topic ‘Parasolid Error: Failed in function PK_BODY_boolean_2 with error PK_ERRO’ is closed to new replies.
6625
1311
