November 7, 2023 at 7:36 amMichael AeschbacherSubscriber
I created a project to simulate the influence of an inductive solder coil to our PCB. For this I have a transient analysis with external schematic. To get a good mesh I created an EddyCurrent simulation with the identical geometry and schematic and linked it to the transient simulation.
Now I want to simulate different setups which I can configure with project variables. I did parametric simulation with different test coil sizes and distances between solder coil and PCB but the result is always the same.
I get two warnings during the simulation (see picture below). May these be the reason for identical results in simulation? How can I solve these warnings? I don't understand what the problem is.
I would attach my project here, but I don't see the possibility to attach a file to my post.
I hope someone can help me. Let me know if you need more information.
November 8, 2023 at 7:29 pmGLUOAnsys Employee
The warnings is from one of your object created with UDP. You could select the object, go to modeler>>purge history to get rid of the warining.. I do not think this is related t your result. If you would like to have an engineer check your project, please use the support button at the left of this page.
GL
- The topic ‘Parametric simulation delivers identical results’ is closed to new replies.
- HFSS Incident Plane Wave excitement mode
- Question for Maxwell
- Simulation of capacitor combining eddy currents with displacement currents
- How to calculate eddy and hysteresis losses of the core?
- Ansys Maxwell 3D – eddy current
- How to determine initial position in motion setup
- dq graph non-conformity
- How to customize pulse waveform and injection site in microstrip array
- 180 Degree Phase Shift When Measuring S21
- Simplorer+Maxwell Cosimulation results and Maxwell results mismatch
1301
591
544
524
366
