Parameter definition for Ansys Mechanical Postprocessing
    • Esmond Chan
      Does anyone know where can i define a global parameter where i can retrieve it for my postprocessing in userdefined function? if i define it as identifier, it doesn't seems to work since im talking about a singular value here.
      Help very much appreciated!
    • Akshay Maniyar
      Hi Esmond,
      Can you add some inline images describing your issue so that it will be easy for forum users to understand and help you?
      Thanks,
      Akshay Maniyar
    • Esmond Chan
      Hi Akshay,
      Thanks for your reply.
      This is rather easy by multiplication of 2. But it get tidious with the number of used defined results.
      Is there a way i can define 2 as a global parameter?
      Thank you!
      Esmond
  • The topic ‘Parameter definition for Ansys Mechanical Postprocessing’ is closed to new replies.
