March 23, 2024 at 8:17 pm
Mahmut Han NeÅŸeli
SubscriberHi everyone;
I want to analyze oven resistance. I am using the Thermo-Electric module.
I choose the boundary conditions of 220v voltage from one end of the bar and 0v voltage from the other end.
Choosen radiation for the "temperature" condition. The environment temperature is set at 10°C.
But I can't get logical results. Can you help me?
March 26, 2024 at 1:16 pm
Praneeth
Ansys EmployeeHi,
Thank you for reaching out to the Ansys learning forum.
Please let us know which Ansys tool you are using to help us serve you better.
Best regards,
Praneeth.
- The topic ‘Oven Resistor Thermo-Electric’ is closed to new replies.
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
- Classic Icepak – clarifications on Boundary condition
- Link the Circuit to 3D Terminals
- Rectangular Coil in Maxwell for WPT using solid block
- Magnetic Dipole moment calculation
1494
1376
1209
