Electronics
Electronics
Out of memory, HPC settings, Network
    • drjVIKKU
      We have 512GB RAM but error showing
      We already given 95% RAM limit.
      Moreover, mention How to do HPC properly i.e. .accessing of all cores and RAM of other workstation. We are already using server license for different workstation via network. We have pool and HPC pack license.
      We have 40 cores & RAM 512GB three workstation. We want to make it 120Core & RAM 1536GB for simulation. Kindly help.
      Thank you
    • AndyJP
      this problem is not common in 64-bit windows kernel, but you may deal with memory fragmentation. It was a big problem plaguing all x86 windows. In Linux the memory manager is more flexible, so you can try using linux version, or remove all the non-relevant software, particularly antiviruses from the simulation workstation.
      another guess... GB may mean 1000 Mb, or 1024MB... lets calculate the worst case:
      477*1.024/0.95=514.2Gb required
    • AndyJP
      HFSS 2020/2021 does not scale with core number per task. probably, bad programming. but it may be scaled with many tasks. therefore do not use large multicoring - use a distributed network of 4-8 core machines with the fastest CPU clocks available.
    • Matt Madore
    • drjVIKKU
      While opening link
      Please verify
    • AndyJP
      >The page cannot be displayed because an internal server error has occurred.>
      Thats per design. You need a license token in a cookie. Go to HFSS, press F1. When the help is opened, go to the link. Awful design, very slow and hard to use. I had to wait 15 minutes today in order to see some specific features config. I prefer the old offline hypertext manual when available.
    • Matt Madore
      Offline Local Documentation is available for paid licenses for customers with Customer Portal accounts. If you're a student you may ask your faculty contact to download for you. It's listed under the Documentation section of the downloads page. https://download.ansys.com/Current%20Release
Viewing 6 reply threads
  • The topic ‘Out of memory, HPC settings, Network’ is closed to new replies.
