Radiant Intensity is the power per solid angle in steradians as a function of incident angle upon the detector, while Coherent Irradiance is coherent power per area as a function of spatial position on the detector (Help file: The Analyze Tab (non-sequential ui mode) » Detectors Group » Detector Viewer). Hence, if you are using a coherent source I would expect to see on the wall the results from the coherent irradiance.
For more information on the radiant intesity I would suggest to go through this post: How is radiant intensity defined?
Kind Regards,
Niki
