June 30, 2023 at 8:31 pmANTONIS KANTZAVELOSSubscriber
Hello! I'm trying to run this calculation with gravity using Direct Integration. As it is shown, it does not converge in a practical amount of time (30,000-40,000 iterations). Will ISAT probably solve my problem without changing my final results (velocity and temperature plots, contours, etc)? Any help would be really useful!!Â
July 3, 2023 at 9:28 amRobForum Moderator
What is the contour of? Where are the inlet(s)? Is it transient?
July 3, 2023 at 11:05 amANTONIS KANTZAVELOSSubscriber
Hello! It is the static temperature contour, steady problem. I switched to ISAT method and after 1 day or so it converged (the contour was smooth without the fluctuations) so its all right! Thank you for your help whatsoever!
- The topic ‘NUMERICAL ERROR’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Mass Conservation Issue in Methane Pyrolysis Shock Tube Simulation
- Script Error
- convergence issue for transonic flow
- RIBBON WINDOW DISAPPEARED
- Running ANSYS Fluent on a HPC Cluster
635
599
591
366
