Ansys Products
Ansys Products
Not enough HPC Parallel licenses
    • Eun Jung Chae
      I am running Ansys Fluent 2022 R2 on three workstations, 2 of which run without any issues. However one of these workstations only allows 4 Parallel licenses to be used. Prior to updating to 2022 R2, 2019 R3 would allow the use of 20 Parallel licenses. Any help to getting around this issue? Is this a server license distribution error or should I uninstall and redownload 2022 R2?
      "Host spawning Node 0 on machine "WS1" (win64).
      Unable to spawn node: license not available.
      ANSYS LICENSE MANAGER ERROR: Not enough HPC Parallel licenses 20/4"
      Thank you.
    • George Karnos
      Under %TEMP%\.ansys, you should see licdebug files
      check the fluent licdebug file as well as the ansyscl.hostname.log file for erors
      Also, If you open the ANSYS Client settings and choose FlexNet Publisher License Status
      Post the status
      Also, can you post the license file, without hostnane, that is installed on the license server?
      • Eun Jung Chae
        Here is a copy of the FlexNet Publisher License Status, I am unable to upload the txt file.
          ansyslmd: UP v11.19.0
        Feature usage info:
        Users of anshpc:  (Total of 316 licenses issued;  Total of 172 licenses in use)
          "anshpc" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2023
          vendor_string: customer:00617639 tp:a
          floating license
            012542567 n075.cluster.com n075.cluster.com 64086 (v2019.1113) (-- 401), start Sat 10/29 4:01, 96 licenses
            CFSL CHAE_SERV CHAE_SERV 34404 (v2022.0502) (-- 810), start Thu 11/3 23:59, 76 licenses
        Users of 1spacdes:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of a_jt_reader:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of a_spaceclaim_dirmod:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of a_spaceclaim_faceteddata:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of acdi_adprepost:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of acfd_vki:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of acfx_bldmdlr:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of acfx_pre:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of acpreppost:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of advanced_meshing:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of afsp_gui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of afsp_optigrid:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of afsp_viewmerical:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of agppi:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of am_module:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of am_prep:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of am_print:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of ans_act:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of ansrom:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of ansys:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of aqwa_pre:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of aqwa_solve:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of cfd_base:  (Total of 55 licenses issued;  Total of 2 licenses in use)
          "cfd_base" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2023
          floating license
            012542567 n075.cluster.com n075.cluster.com 64086 (v2019.1113) (-- 301), start Sat 10/29 4:01
            CFSL CHAE_SERV CHAE_SERV 34404 (v2022.0502) (-- 726), start Thu 11/3 23:59
        Users of cfd_polyflow_ui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of cfd_preppost:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of cfd_preppost_pro:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of cfd_solve_level1:  (Total of 55 licenses issued;  Total of 2 licenses in use)
          "cfd_solve_level1" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2023
          floating license
            012542567 n075.cluster.com n075.cluster.com 64086 (v2019.1113) (-- 201), start Sat 10/29 4:01
            CFSL CHAE_SERV CHAE_SERV 34404 (v2022.0502) (-- 626), start Thu 11/3 23:59
        Users of cfd_solve_level2:  (Total of 55 licenses issued;  Total of 2 licenses in use)
          "cfd_solve_level2" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2023
          floating license
            012542567 n075.cluster.com n075.cluster.com 64086 (v2019.1113) ( -- 101), start Sat 10/29 4:01
            CFSL CHAE_SERV CHAE_SERV 34404 (v2022.0502) (-- 526), start Thu 11/3 23:59
        Users of cfd_solve_level3:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of disco_level1:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of disco_level2:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of dsdxm:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of dyna:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of dynardo_osl:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of dynardo_osp:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of elec_solve_2d:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of elec_solve_icepak:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of elec_solve_level1:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of elec_solve_level2:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of electronics_desktop:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of electronics2d_gui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of electronics3d_gui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of electronicsckt_gui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of emag:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of ensight_enterprise:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of envision_pro:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of explicit_advanced:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of explicit_basic:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of fluent_meshing:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of fluent_meshing_pro:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of fluent_setup_post:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of fluent_setup_post_pro:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of forming_level1:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of forming_level2:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of forte_3:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of granta_sim_mat_data:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of ice_translator:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of mat_designer:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of optislang_level1:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of optislang_level2:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of optislang_level3:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of pemag:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of pexprt:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of piautoin:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of picatv5:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of piproe:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of pisoledg:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of pisolwor:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of piug:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of preppost:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_ckcompute:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_ckgraph:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_ckpost:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_ckpreproc:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_ckui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_fortemesh:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_forteui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_forteviz:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_kineticsapi:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_mechforte:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_mechmfc:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_mechsoot:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_mechwb:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rd_reactionwbui:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rdacis:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of rdpara:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of sherlock:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of simplorer_LibSMPS:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_catiai:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_drtrain:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_drtrain_pre:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_links:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_mesh:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_mesh_pre:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_para:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_post:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_pre:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of vmotion_step:  (Total of 55 licenses issued;  Total of 0 licenses in use)
        Users of dysmp:  (Total of 75 licenses issued;  Total of 0 licenses in use)
  • The topic ‘Not enough HPC Parallel licenses’ is closed to new replies.
