October 2, 2024 at 12:08 pm
hakaera
Subscriber*** ERROR *** Â Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â 455.828 Â TIME= 14:58:25Element 19509 (type = 1, PLANE183) (and maybe other elements) hasbecome highly distorted. Â Excessive distortion of elements is usuallya symptom indicating the need for corrective action elsewhere. Â Tryincrementing the load more slowly (increase the number of substeps ordecrease the time step size). Â You may need to improve your mesh toobtain elements with better aspect ratios. Â Also consider the behaviorof materials, contact pairs, and/or constraint equations. Â Please ruleout other root causes of this failure before attempting rezoning ornonlinear adaptive solutions. Â If this message appears in the firstiteration of first substep, be sure to perform element shape checking.*** WARNING *** Â Â Â Â Â Â Â Â Â Â Â Â CP = Â Â 455.828 Â TIME= 14:58:25The unconverged solution (identified as time 1 substep 999999) isoutput for analysis debug purposes. Â Results should not be used forany other purpose.
October 2, 2024 at 12:39 pm
Armin
Ansys EmployeeHello,
Check the following video on how to handle element distortion error for hyperelastic materials (with the majority of guidelines applicable to other materials as well):
How to Handle Element Distortion Errors in Hyperelastic Materials — Lesson 3 - ANSYS Innovation Courses-
October 5, 2024 at 11:49 am
hakaera
SubscriberHello, this message pops up when i run the analysis to define the timestep of the plastic collapse load on a thin strip with an elliptical hole on ansys mechanical apdl. i checked the mesh and there was no error shown by the software. i try to increase the number of substeps or decrease the timestep size but still nothing. I am not sure if there is any problem with the design or shape of the elliptical hole as i couldn’t find a command for the design of an ellipse(major axis is 20mm and minor axis is 10mm) located at the center of the thin strip.
October 2, 2024 at 2:57 pm
hakaera
Subscriberthank you
5794
