TAGGED: boundary-condition, expression, expression-editor, heatflux, udf
May 23, 2024 at 8:25 am
Philip Lim
SubscriberHi,
I want to use non-uniform heat flux data as below. The data is heat flux collected every hour.
Based on the equation, I changed my heat flux expression as follows. Because my time step size is 0.5 s, number of steps is 172800.
Plus, the above data was collected hourly - that is how I came up with the equation below.
However, it says the value is 35. 782 in kg/s^3. not in w/m^2
Can anyone help me with this problem?
May 23, 2024 at 10:40 am
SRP
Ansys EmployeeHi,
Both are same. It can be understood as if you replace 'W'=J/s=N.m/s=kg.m.m/s^3
so W/m^2=kg.m.m/(m^2.s^3)=kg/s^3
Hope this helps you.
- The topic ‘Non-uniform heat flux expression’ is closed to new replies.
