January 21, 2026 at 9:29 am
James411project
SubscriberHello everyone!
I am currently using the Wet Steam Model in ANSYS Fluent. In this model, the mass source term for the vapor phase is defined by two components: droplet nucleation and droplet growth, as shown in the equations below:
Based on my research into non-equilibrium condensation flows, both droplet condensation (growth) and evaporation should occur. This implies that the droplet growth rate can be either positive or negative.
However, according to the definitions provided in the Fluent documentation, it appears that the droplet growth term is treated as positive only. I am curious: How does the Wet Steam Model account for the droplet evaporation process?
Thanks for any insights you can provide.
January 21, 2026 at 10:21 am
Forum ModeratorHave a look here https://ansyshelp.ansys.com/public/account/Secured?returnurl=/Views/Secured/corp/v252/en/flu_th/flu_th_sec_wet_steam_phase_change.html If T>T0 and (or?) r*>r then the growth terms will be negative.
January 21, 2026 at 12:45 pm
James411project
SubscriberThank you for your professional reply. In my calculations, I have encountered another issue: if the droplet evaporation rate is too high, it means that the already condensed liquid phase will be depleted. If the evaporation source term is too large, could this result in a negative liquid phase mass fraction (meaning the liquid in the grid is completely exhausted, even turning negative)? Does this imply that we should consider imposing a limit on the droplet evaporation rate?
January 21, 2026 at 1:24 pm
Forum ModeratorIf you're converging the solution I doubt liquid fraction could become negative.
- 您必须登录才能回复此主题。
- Application of EDC occurs flame extinguishing
- Please help me check if there are any issues with the UDF.
- Difficulty in Complex Source Term Linearization
- Must EDC model need an initial flow field?
- Negative droplet growth rate in Fluent wet steam model
- Please help me analyze the multiphase flow model for the phase change of liquid
- Energy Source Term formulation for multi-component condensation
- Compile the UDF code and apply it to the DPM.
5884
1306
