September 16, 2024 at 4:53 pm
shehlarao7207
SubscriberI have a system (Bottom electrode is Pt and top electrode is Cu and the medium between them is dielectric TnOx), when I am applying voltage (5V on the Cu electrode and 0V on the Pt electrode) the Cu^+ ion will move towards Pt through dielectric medium and neutralize and pile up on the Pt electrode and will make an cone shape that will ultimately touch the Cu electrode surface. Now the cone radius will gradually decrease as its close to Cu electrode, so then therefore there will be very only one or two Cu atoms Cu electrode because of high resistance, once this path will form the current will flow from it, I want to see the strength of electric field near the top of cone, the results should be “Very high electric field if the radius is small” therefore it will be very difficult to knock out or add more atoms there.I have investigated Poisson's equation and tried to apply boundary condition but my guess I am wrong, one of my friends also thinks same, there might be some discontinuity while checking the potential on the truncated cone. Is there a way I can simulate through ANSYS.I would highly appreciate if someone can help. Thanks -
September 23, 2024 at 8:59 am
Mrinmoy Bharadwaj
Ansys EmployeeHello Shehlarao7207, Kindly Explore Ansys Charge Plus for your requirement.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
1510
1386
1209
