May 31, 2020 at 2:27 pm
Alr.esmaily
SubscriberHi dears
There is a gap between two sheet metal body, upper body thickness is 1mm steel and blower part thickness is 0.5mm stainless steel. So in real, two sheet metal bodies are tendency and pre-stressed by three bolts. NowÂ
How can i solve this problem? (Pictures attached)
Cross section view of assembly. Main question of simulation is finding spring resistance of purple body in below figure. butÂ
May 31, 2020 at 6:16 pm
peteroznewman
SubscriberSplit the cylindrical face of the screw shank into two faces at the plane of the light grey part. Then use Bonded Contact to have the lower face of the screw connect to the light grey part. You already have Bolt Pretension, but now you can scope it to the upper face of the screw shank. You can enter either a displacement of < 1 mm or a Force to squeeze the top sheet down.
You will need Frictional contact under the screw head to the top surface of the top part.
You will need frictional contact between each part that touches another part.
- The topic ‘Near Contact Sheet Metal Case! (Gap Filling Problem)’ is closed to new replies.
- At least one body has been found to have only 1 element in at least 2 directions
- Script Error Code:800a000d
- Element has excessive thickness change, distortion, is turning inside out
- Elastic limit load, Elastic-plastic limit load
- Image to file in Mechanical is bugged and does not show text
- Help to do quasistatic analysis in static structural module
1937
839
599
591
366
