nanofluid is flowing inside the tube shown in fig below & air is flowing over fins through enclosure
October 18, 2021 at 5:47 am
sadhurajesh
SubscriberOctober 18, 2021 at 2:41 pmRob
Forum ModeratorI assume the two flow domains aren't supposed to be connected? Ie the nanofluid isn't mixing with the air?
October 25, 2021 at 8:49 amsadhurajesh
SubscriberI don't know both fluids are mixing or not. But while I am trying for convergence using fluent solver, I am getting floating-point exception and continuity diverging
October 25, 2021 at 9:46 amRob
Forum ModeratorYou need to decide if the fluids should or shouldn't mix. That determines whether you need to include multi phase models. What is the mesh quality?
October 25, 2021 at 10:02 amOctober 25, 2021 at 11:09 amRob
Forum ModeratorOK, so you need to rethink the geometry so that the two streams can't mix. You also need to find where the highly skewed cells are and sort those out: 0.99999 skew is essentially flat, and will cause the solver to fail.
October 25, 2021 at 12:14 pmsadhurajesh
Subscriberhow to sort out highly skewed cells
October 25, 2021 at 1:11 pmRob
Forum ModeratorIt depends on what's causing them. It could be changes to geometry or cell sizing.
Viewing 7 reply threads- The topic ‘nanofluid is flowing inside the tube shown in fig below & air is flowing over fins through enclosure’ is closed to new replies.
5939
1307
