December 4, 2021 at 7:40 amEmiliano MaldonadoSubscriber
Hi everyone,
I am trying to assign the COMBIN14 command to a volume's surface, but I cannot find the way to do that. What I am doing is the following:
1) I assign a named selection for the surface (the name is, for instance, "FORMATION_LEVEL")
2) After that, I try to find an ID/ET for the named selection in the *.dat input file. The only I can find is the following:
December 6, 2021 at 4:13 pmGovindan NagappanAnsys Employee
You can use the *GET command to find the maximum element type number used. Then use a number greater than that for the elements you are creating
Example:
*get,total_etyp,etyp,0,num,max !get maximum element type number
ET,total_etyp+1,14 !set combin14 element type number = total_etyp+1
Hope this helps
December 6, 2021 at 6:00 pmmrifeAnsys Employeecan I ask why you are doing this via a commands object when springs are supported natively in the UI?
Mike
December 8, 2021 at 5:42 pmEmiliano MaldonadoSubscriberThanks for your interest.
What I'm trying to do, is to include a command for a "ground-to-solid" spring. The purpose of the command is to include a table with values of stiffness and damping which are frequency dependent:
I do know I'm doing something wrong, the problem is that I do not know where's the error. Any help shall be much appreciated.
Best regards!
December 8, 2021 at 8:00 pmViewing 4 reply threads- The topic ‘Named selection’s ID/ET’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to select the interface delamination surface of a laminate?
- How to apply Compression-only Support?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
Top Contributors-
1191
513
488
225
209
Top Rated Tags© 2024 Copyright ANSYS, Inc. All rights reserved.
