November 21, 2025 at 11:04 am
fanbo9802
SubscriberI am wondering if I want to use EDC model to simulate combustion with a chemical mechanism, should I obtain an initial field using ED or other simpler methods? And should the results include a temperature result or just a cold flow field result?
November 24, 2025 at 9:31 am
Ren
Ansys EmployeeEither approach should work. You can use a computationally more efficeint model such as the EDM to first obtain a reasonably converged combustion solution and then switch to the EDC calculation, or obtain a non-reacting flow solution to first establish the flow field and the main species (fuel and oxidizer speces) field, then start he full EDC combusiton calculation. In the second approach, you need to numerically "ignite" the mixtrure by patching.
November 26, 2025 at 12:49 pm
fanbo9802
SubscriberDoes the FR/ED approach support the multiple reactions? I want to simulate spray combustion through EDC, and I want to use a more efficient model to simulate an initial field with a reduced mechanism that contains 20 species and 39 reactions. Is it reliable to import the mechanism with the FR/ED model?
November 26, 2025 at 2:24 pm
Ren
Ansys EmployeeI would not recommend using the FR/ED and a detailed mechanism for the initial solution calculation. You have many options:
ED with a 1-step or 2-step global scheme, or
Non-premixed model, or
ED with Relax to chemical equilirium
The precursor calculation and the EDC calculation do not need to use the same mixture material.
- 您必须登录才能回复此主题。
- Application of EDC occurs flame extinguishing
- Please help me check if there are any issues with the UDF.
- Difficulty in Complex Source Term Linearization
- Must EDC model need an initial flow field?
- Negative droplet growth rate in Fluent wet steam model
- Please help me analyze the multiphase flow model for the phase change of liquid
- Energy Source Term formulation for multi-component condensation
- Compile the UDF code and apply it to the DPM.
5889
1306
