TAGGED: #mechanical-#workbench, geometry, moving-heat-flux
December 4, 2024 at 12:35 am
mateus.chaves
SubscriberHi, everyone
I want to understand what influence has the geometry I select in the results and which faces I should use for my simulation.
I'm simulating circunferencial and longitudinal fillets. The middle point is the path of the heat source. I wanna know if I should select the external faces, the internal faces, all of them ?
Can somebody help me?
Thank you for your attention. -
December 11, 2024 at 5:28 am
Ashutosh Srivastava
Ansys EmployeeAre you trying to simulate deposit weld? If yes, then I would suggest you to use the deposit weld ACT extension.
December 13, 2024 at 2:14 am
mateus.chaves
SubscriberWhere I can find this extension? Never heard about that before, and didn't find it anywhere.
December 13, 2024 at 6:57 am
1306
