February 6, 2024 at 12:33 am
Brian Smith
SubscriberHi All, I am trying to generate a mesh for a fan all other sections are able to be generated apart from the motor casing, see below.
When i go into space claim to examine the geometry I notice only the motor casing as many sharp edges (over 100 of them). Would it be wise to round all these sharp edges off? is there a quick way to do it? or can I still generate a mesh by changing some mesh settings? Thanks in advance!
February 6, 2024 at 1:29 am
peteroznewman
SubscriberI suggest you read my reply describing shell meshing in this discussion:Â /forum/forums/topic/thin-walled-geometry-mesh/
- The topic ‘Motor Casing Meshing Issues Sharp Edges?’ is closed to new replies.
