Moment Convergence Issue in structural Analysis for Lifting simulation
    • Adarsh_Gupta
      Hello, all
      I am trying to simulate lifting operation for a complex assembly. However, I am facing moment convergence issues for the same. I request you all to guide me in sorting out this issue. The model is connected to the lifting point using springs (tension only) of 1e13 N/mm stiffness to simulate the slings effect. The model is converging for springs with both behaviour where in springs provides the resistance to both tension and compression forces. The remote point is located above the center of mass of the system. I have introduced the small springs of 10N/mm at the corner vertices for mathematical stability. Scaled acceleration is applied to simulate the exact weight of assembly in simplified model used.
    • Adarsh_Gupta
      Hi,nnI am able to sort the moment convergence issue by changing the type on contact behaviour. Please consider this post closed.n
    • Karthik Remella
      Administrator
      Thank you for letting us know and glad that you were able to resolve it. nBest,nKarthikn
  • The topic ‘Moment Convergence Issue in structural Analysis for Lifting simulation’ is closed to new replies.
