February 25, 2023 at 12:52 amTudor MironSubscriber
I would like to learn how can I model a sandwich panel with hard insert (metal) placed in between skins. My initial idea was to use solid modeling in ACP and assemble metal parts with solid composite parts in Static structural using contacts/bonding.
1. I created OSS that includes full face of the panel. I created top skin ply’s using this OSS.
2. I created another OSS that covered full face but has a cutout region where metal insert should be placed. I created a core ply using this surface.
3. I created bottom skin using first OSS (one that covers full face of the panel)
4. Now, when I try to create solid model, all is fine with top skin and core layer, but bottom skin has a hole/cutout in place where there’s no core.
Any suggestions on how can I avoid this unwanted cutout in my “overcore” ply’s?
What is the proper way to model such structures – sandwich panels with metal inserts?
Many thanks
Ted
February 25, 2023 at 4:04 pmTudor MironSubscriber
Update: I figured out how to deal with this problem within ACP - using cutoff geometries within SolidModel branch I created a cavity within core where metal insert supposed to be placed in Static Structural assembly.
Thanks
Ted
- The topic ‘Modeling composite sandwich panel with hard (metal) inserts.’ is closed to new replies.
- Problem with access to session files
- Ayuda con Error: “Unable to access the source: EngineeringData”
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- Geometric stiffness matrix for solid elements
- How to apply Compression-only Support?
- How to select the interface delamination surface of a laminate?
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- SMART crack under fatigue conditions, different crack sizes can’t growth
1241
543
523
225
209
