minimum cell length for poly-hexcore mesh
    • buksa
      Hello.
      I created a mesh using poly-hexcore. Now I want to set a time step in the simulation. For this I need a minimum cell length. Ansys meshing displays the smallest, largest and average "volume" of the cell. I can't find values relating to length anywhere. Where can I get the minimum length value for the poly-hexcore mesh?
    • Federico
      You can use the minimum cell length that you used to create your mesh.
  • The topic ‘minimum cell length for poly-hexcore mesh’ is closed to new replies.
