TAGGED: ansys-mechanical, mechanical, mesh-generation, ryzen
October 22, 2021 at 5:26 pm
SimonZiegler
SubscriberI'm trying to simulate a beam. When I try to create a mesh with all the default settings I get an error message:
"The mesh generation did not complete due to poor quality elements or incorrect input. Please try meshing with another mesh method or different mesh options."
I'm running a Lenovo Legion 5 with:
- AMD Ryzen 5800H
- G.Skill RipJaws with 32 GB RAM (2 x 16 GB) running at 3200 MHz and CL22
- Nvidia RTX 3060 mobile
I've tested the same install files (the same zip) on a different machine. A desktop with:
- AMD Ryzen 3600X
- G.SKill RipJaws with 16 GB RAM (2 x 8 GB) running at 3200 MHz and CL16
- Nvidia GTX 1070
On this desktop machine everything is working as excepted (meshing works without errors).
I also uninstalled the complete Ansys package and removed every Ansys related directory and file I found and then reinstalled it (with reboots before and after every installation).
October 27, 2021 at 6:42 pmGeorge Karnos
Ansys EmployeeOctober 29, 2021 at 7:12 pmSimonZiegler
SubscriberI've got it running thanks to this solution, which can also be found in one of the threads Geo Karnos linked to: /forum/discussion/comment/92130#Comment_92130
It was caused by an old dll from another program
Viewing 2 reply threads- The topic ‘Meshing stops with error on Ryzen 5000 mobile’ is closed to new replies.
