October 31, 2021 at 4:29 pmBorealinSubscriber
I'm learning how to use ansys to analyze static structural force, and I follow the tutorial, using the model as it is given.
I want to mesh the model just as the Surface Mesh Preview, using Quad face,
November 1, 2021 at 5:29 amAkshay ManiyarAnsys Employee
I tried creating similar geometry and tried to mesh it and I got mesh as per the first image. Do you see any warning while meshing in messages?
Can you try inserting a method by right clicking on mesh and use sweep method for meshing? Also, check the default method for meshing set in your system. Go to File>options> meshing>default method and check if it set to patch conforming/sweep, which should be default.
regards Amaniyar
Viewing 1 reply thread- The topic ‘Mesh result do not match preview’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
Top Contributors-
1406
599
591
555
366
