August 25, 2024 at 3:49 pms310413Subscriber
Hi everyone, I'm trying to automate a simulation and I need to write the input file (.dat) of a static structural analysis. In mechanical ACT console I tried with the command ExtAPI.DataModel.Project.Model.Analyses[0].WriteInputFile('filename') but I don't know if and where it is saving the .dat file. Does anyone know where the file is saved and eventually how can save it in a desired folder? Thanks
August 26, 2024 at 7:15 amHarshvardhanAnsys Employee
This is a duplicate post so I am closing this forum topic.
Please find the following link for the discussion:
Mechanical scripting (ansys.com)
Thanks,
Harshvardhan
- The topic ‘Mechanical scripting – write input file’ is closed to new replies.
Ansys Innovation Space
- At least one body has been found to have only 1 element in at least 2 directions
- Error when opening saved Workbench project
- How to apply Compression-only Support?
- Geometric stiffness matrix for solid elements
- Frictional No separation contact
- Timestep range set for animation export
- Image to file in Mechanical is bugged and does not show text
- Script Error Code:800a000d
- Elastic limit load, Elastic-plastic limit load
- Element has excessive thickness change, distortion, is turning inside out
599
591
565
366
