July 21, 2025 at 2:03 pm
gtderomance
SubscriberDear Ansys community,ÂI need help with Mechanical 2025 R2 within a student license. I've been following the introductory and modeling courses with Discovery, but launching Mechanical 2025 R2 seems impossible. After double-clicking the "Model" button within a Static Structural element, I get the error visible in the first attached image. Even when trying to launch the program directly through execution, it crashes. I thouroughly checked the system requirements, and there seems to be no issue there, these are the details of my computer:- 16GB physical RAM
- Nvidia GeForce RTX 3073 Laptop GPU, 8GB
- AMD Ryzen 7 6800H with Radeon Graphics, 3.2 GHz
- Windows 11 24H2
Nothing seems to work. I have visited the troubleshooting threads in support forums, reinstalled the entire suite, tried the name replacements (ansys to ansys_old), etc...ÂAny help will be greatly appreciated.Thank you!! -
July 22, 2025 at 6:04 am
Ashish Khemka
Forum ModeratorHi,
Can you try creating a new model/ project and see if the error persists?
Ashish Khemka
July 22, 2025 at 8:36 am
gtderomance
SubscriberHello,
I tried creating a different geometry, but still doesn't work.
For reference, I can start Mechanical APDL with no apparent issues, so I'm guessing that the problem comes from the Mechanical GUI?
I've tried opening Mechanical directly again, and I get a different error message that I have attached.
July 23, 2025 at 12:17 pm
MangeshANSYS
Ansys EmployeeÂ
please check for and remove any spaces in job names and paths to avoid the error above
i.e. save projects to something like c:\my_projects\Simulation\Project_abc_123\
etc etc (as you can see the only characters i used are a to z, 0 to 9 and underscore
Also please check free disk space and if an antivirus is blocking access by Ansys applications to the disk or from running
let me know if that helps
June 26, 2026 at 1:33 pm
MangeshANSYS
Ansys EmployeeHello
When does this error come up?
Do you simply import a simple IGES geometry into Geometry cell in to a Static Structural analysis system in Workbench and double click on model?Â
Does it happen when you click on on "update project" or solve button ?
July 22, 2025 at 4:31 pm
Ashish Khemka
Forum ModeratorHi,
Please let me share this with the team, and they can comment more.
Ashish Khemka
June 26, 2026 at 8:54 am
dyfanobelva
Subscriberhi anyone have solution for this problem??
6765
1330
1127
