Electronics
Electronics
Maxwell2D Solver Error
    • Bobby11
      Why am I getting below error?
      "Coreloss: Output stator and rottorr object name error"
    • DELI
      yes stator and rotor loss could be seperated.
      In project manager window, Analysis->Setup1. In the new window, go to Solver tab->check "Output per object core loss".
      After checking that box, the report would have rotor and stator loss separated.
      Note, this would only work when you are using materials with core loss model setup.
    • Bobby11
      Thank you ..!!
  • The topic ‘Maxwell2D Solver Error’ is closed to new replies.
