June 23, 2021 at 7:11 am
atulsingh92
SubscriberI have a heat exchanger to look at.
There is a main inlet manifold, and there is an inlet to pipes and exit from pipes and there is a main outlet manifold.
Is there a way I could obtain the mass flow rate at the inlets and outlets of the pipes?
As they are not defined as inlets and outlets, becuase they are no boundary at them, I cannot obtain the mass flow rate through them. The manifold just connects to the pipe. I tried drawing a section at those inlets and outlets, but the properties for various post processing do not show mass flow rate.
please suggest a workaround
June 23, 2021 at 7:58 amaitor.amatriain
SubscriberI guess that you are trying to compute the mass flow rate in Results - Reports - Fluxes. You can also do the same in Results - Surface- Integrals - Mass Flow Rate, and in that case you will have the option of choosing the surfaces that you are mentioning.
Viewing 1 reply thread- The topic ‘Mass flow rate at a section inside a domain’ is closed to new replies.
2788
965
851
599
591
