TAGGED: cfd-microfluidic, fluent, mpm, particle-tracking
January 12, 2021 at 2:17 am
SudharsanSadagopan
SubscriberHi,nHope you are well.nI wish to simulate and track particle motion in a microchannel. Since I don't want my particles to be considered as point masses, I wish to use the macro particle model instead of DPM. However, I am not sure how to visualize the results since I run the simulation on a remote compute cluster. I only have the final result data file. Can you kindly suggest a way to extract particle tracking data once the result data file has been imported to fluent? Also, there seem to be very limited resources on macro particle modeling in the ANSYS Help guide and online forums, so any general tutorial on the Fluent macro particle model would also be very helpful.nThanks.n -
January 12, 2021 at 7:47 am
Amine Ben Hadj Ali
Ansys EmployeeThere are some tutorials but are not exposed on the Standard Tutorial Webpage. Please be aware that the default tools for post processing do not work for MPM.nIn the MPM panel you can display Injections.nAlso please look into https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v211/en/flu_ug/flu_mpm_using_mpm_init.html. One MPM is initialized some macros will be avaiable to allow you post-porcessing MPM and using the macros as calculation activity if you want to autosave overlays of particles with the flow.n
- The topic ‘Macro Particle Model simulation not giving expected results’ is closed to new replies.
Ansys Innovation Space
- How do I get my hands on Ansys Rocky DEM
- convergence issue for transonic flow
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
- Script Error Ansys
933
792
599
591
