Ansys Products
Ansys Products
LS-DYNA output extension
    • Fady Elshazly
      I am using mpp and history node id. I need to save the recorded nodes in history node id in a file that can be red directly without the need to open lsprepost again. I mean to import it in matlab or Python and read it as a txt or other readable extensions.
      Thanks
    • Ram Gopisetti
      you can conver the nodeout file int an text file, no harm in that
      or you may want to use the some of the best packages in the intreacting with d3plots and binouts from pydpf and other such repo avialble in github
      my fav is the qd lib as in follows
      https://github.com/qd-cae/qd-cae-python
      https://dpf.docs.pyansys.com/version/stable/examples/01-transient_analyses/02-lsdyna_operators.html#sphx-glr-examples-01-transient-analyses-02-lsdyna-operators-py
      cheers, ram
      • Fady Elshazly
        Thank you so much
  • The topic ‘LS-DYNA output extension’ is closed to new replies.
