July 5, 2024 at 3:55 pm
Joshua Monsey
SubscriberHello,
I am attempting to run an impact simulation in LS-DYNA and I keep getting error 70021. Upon Googling the error, it seems to be a memory problem, but I have not yet found a way to fix it. So far I have tried to clean up the model, and gone to the Analysis Settings --> CPU and Memory Management --> Memory Allocation and increasing the value there. Neither has worked so far. What else can I try?
Thank you.
July 25, 2024 at 12:53 pm
ashish.khemka
Forum ModeratorHello,
Please see if the following link helps: How to handle the following error: *** Error 70021 (OTH+21) Memory is set 3717636 words short memory size 70000000 Increase the memory size by one of the following where #### is the number of words requested: 1) On the command line set - memory=#### 2) In the input file define memory with *KEYWORD i.e., *KEYWORD #### or *KEYWORD memory=#### - Ansys Knowledge
Ashish Khemka
- The topic ‘LS-DYNA Error’ is closed to new replies.
