LS Dyna
LS Dyna
LS-DYNA DUALCESE solver
    • Atish Gawale
      How to resolve following error for DUALCESE solver? Any guideline for model setup?
       *** Error 200390 (DCESE+390)
           *DUALCESE_INCLUDE_MODEL
           All *DUALCESE cards must be given inside of the file hierarchy specified
           by a *DUALCESE_MODEL card.
      Atish
    • Nanda
      Hello Atish,
      Upon my quick search, here's what I believe should help:
      • Make sure that the file containing the *DUALCESE_INCLUDE_MODEL card is within the hierarchy of a *DUALCESE_MODEL card. This means that the *DUALCESE_INCLUDE_MODEL card should be in a file that is referenced by a *DUALCESE_MODEL card. Standard *INCLUDE cards are not allowed in this hierarchy.
      • If you are using *MESH cards to define a mesh, ensure that these cards are also within the scope of the *DUALCESE_MODEL card. Any non-*DUALCESE keywords should be defined outside the *DUALCESE_MODEL hierarchy.
      • The structure of the keyword setup for the *DUALCESE solvers is different from the usual LS-DYNA input phase. Each model should be specified with a single file hierarchy, starting with the *DUALCESE_MODEL card. Ensure that your setup adheres to this structure.
      Additionally, to get more information about a specific error message number in LS-DYNA, you can add the following option to the LS-DYNA execution line:
      msg=< error number that you observed in the solver>
      For example, if you run LS-DYNA and you get Error 20368, you can run the following command line:
      "C:\LS-DYNA_Solvers\SMP\ls-dyna_smp_d_R14_118152-gbd64d58a85_winx64_ifort190.exe" i=D:\LSTC_examples\JimDay_library\sphere\input_sphere.k ncpu=-2 memory=20m msg=20368
      Let us know if you get more information by adding this line.
      Nanda.
      Introducing Ansys Assistant a 24/7 AI-powered virtual assistant for active Ansys academic customers.
      Have a look at our public help documentation website: Ansys Help
      For more exciting courses and certifications, hit this link: Ansys Innovation Courses | ANSYS Innovation Space
