Electronics
Electronics
Locked rotor current simulation
    • Mohammadreza Hojati
      Hi everyone. I have simulated a BLDC named A2212 with RMxprt in Ansys Maxwell. Its nominal power is 280W. Its coils consist of a stranded winding with 24 thin wires with 5 turns. The software has calculated its locked rotor current as 850 Amps. Is this logical or something wrong is with it? Anybody could help me with that? Thanks
    • Navya Chode
      Hi Mohammadreza,
      Which version of AEDT are you using?
      Are you calculating this data in RMxprt or in Maxwell?
      Can you share the design sheet/results screenshots of your RMxprt and Maxwell?
      Navya
  • The topic ‘Locked rotor current simulation’ is closed to new replies.
