lift and drag coefficient
    • chandanapdev
      Hai,
      I am doing a project of pressure evaluation on rooftop solar panels subjected to wind loads.
      When i started calculating the coefficients, during iteration i found that my lift coefficient values and drag coefficient values are very high. My building model is of dimension, 0.525 x 0.52 x 0.4 m and the panels over that is of dimension 0.42 x 0.04 m. i have used hybrid meshing and the cells are about 6 millions. I didn't complete the iteration but felt the answer is wrong. My reference values are shown below. as you can see, the values i have shown in console are at a range of 10^20 + ...
      Can anyone help me please.
    • chandanapdev
    • Kalyan Goparaju
      Can you please share a screenshot of how you setup your report definitions?
      Thanks,
      Kalyan
    • chandanapdev
    • chandanapdev
      Hai
      Thank you for your reply.
      Is that the detail you asked for sir? I have created named selection for each panels and selected those panels to plot drag and lift coefficients.
    • Kalyan Goparaju
      Yes, this was what I was asking for. I notice that the Force vector is 1 0 0. Have you cross-checked it to make sure that it is infact the appropriate force-vector for Drag? Can you please share some images of the model?
      Thanks,
      Kalyan
    • chandanapdev
      Hi sir
      Drag force can be in both x and z direction know. even if its towards x or y this value should not come know? This seems to be huge.
      Model of both building and panels over it is shown below. I am considering 0 degree angle of attack.
    • chandanapdev
      the building and panels alone is shown here
    • chandanapdev
Viewing 8 reply threads
  • The topic ‘lift and drag coefficient’ is closed to new replies.
