October 24, 2023 at 5:59 pm
scorsett
SubscriberHello! My research group just had our previous annual Lumerical license expired. We are attempting to host our new license on a new server, running RedHat 9.
We have the new license file ready and saved under shared_files/licensing/license_files
When we attempt to start the license manager using start_ansysli, the ansysli_server.log file records the following information:
2023/10/23 10:35:52 INFO ANSYSLI_CMD=/home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/linx64/ansysli_server
2023/10/23 10:35:52 INFO ANSYSLI_INITIALIZATION_FILE=No initialization file found.
2023/10/23 10:35:52 INFO ANSYSLI_MONITOR=/home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/linx64/ansysli_monitor
2023/10/23 10:35:52 INFO ANSYSLI_PRODORD_FILE='/home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/prodord/ansysli.prodord.xml'
2023/10/23 10:35:52 INFO FLEXLM_LICENSE_FILE='/home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/license_files'
2023/10/23 10:35:52 INFO ANSYSLI_PORT=2325
2023/10/23 10:35:52 INFO Listen Socket Created
2023/10/23 10:35:52 INFO /home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/linx64/lmgrd -c /home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/license_files -l /home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/license.log
2023/10/23 10:35:53 ERROR Could not start FLEXlm server. Please check the FLEXlm log file. Exiting.
2023/10/23 10:35:54 CACHE_SERVER Available licenses from file /home/admin/Downloads/ExterpriseLicensing_2023r2/shared_files/licensing/license_files:
15 dynardo_osl 15 dynardo_osp 60 lum_charge_solve 15 lum_cml_compiler
60 lum_dgtd_solve 60 lum_eme_solve 60 lum_fde_solve 15 lum_fdtd_gui
60 lum_fdtd_solve 60 lum_feem_solve 60 lum_heat_solve 15 lum_interconnect_gui
60 lum_interconnect_solve 15 lum_mode_gui 60 lum_mqw_solve 15 lum_multiphysics_gui
60 lum_stack_solve 60 lum_varfdtd_solve 60 lum_veriloga_solve 180 optishpc
15 optislang_level1 15 optislang_level2 15 optislang_level3
2023/10/23 10:35:54 CACHE_SERVER No active FLEXlm options.
2023/10/23 10:35:54 CACHE_SERVER No active Ansys Licensing Interconnect options.
2023/10/23 10:35:54 INFO Ready to accept connections.Although it ends with "Ready to accept connections", we cannot successfully connect to the new license, from personal PC's, or from the host server itself. In debugging, we've found that netstat results show no processes listening on 1055, 1056, or 1084. We also cannot connect to localhost:1084/ in the browser. Using telnet to open a session with any of the ports also fails.
This seems that it could be related to the "ERROR" lines above, which show that the FLEXlm server cannot be started, but we aren't certain. So far, we've tried ensuring the ports are open with firewall-cmd and iptables, specifying the vendor port in the license file, and a few other attempts, but no luck so far. Is there any clear next step we should try? Thank you!
October 26, 2023 at 4:14 pm
Lito
Ansys Employee@Sabrina Corsetti,
Based on the supported systems for the Ansys license manager, RHEL 9 is not yet supported.
>>ansys-2023-r2-platform-support-by-application-rev.pdf
We have the following Knowledge Base for the Ansys license manager installation, configuration and troubleshooting on Linux:
- Ansys license manager installation guide for Linux – Ansys Optics
- Required libraries and packages for the Ansys license manager on Linux – Ansys Optics
- Ansys license management center (Log Files) – Ansys Optics
- Ansys license manager configuration and license file installation – Ansys Optics
- Troubleshooting licensing issues with the Ansys license manager – Ansys Optics
The Ansys LMCenter Diagnostic files should provide any information on what is happening with the license manager.
e.g. the LM (lmgrd) might not be running if this is missing the 'redhat-lsb' package, etc. -
October 26, 2023 at 9:47 pm
scorsett
SubscriberThank you for the reply! Using RHEL 9 did turn out to be the issue, and we were indeed missing redhat-lsb-core (not originally available for RHEL 9).
Thankfully, redhat-lsb-core is now available through fedora: https://packages.fedoraproject.org/pkgs/redhat-lsb/redhat-lsb-core/Installing lsb-core and relaunching the license manager from the admin account fixed the issues we were having!
October 26, 2023 at 11:23 pm
Lito
Ansys EmployeeYou are welcome, Sabrina. Glad to hear this. Have a great day!
- The topic ‘Licensing for Lumerical: Could not start FLEXlm server. Please check the FLEXlm’ is closed to new replies.
5654
1890
1414
1303
